3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
modeling forum in Renders
1 REPLY 1
304 Views, 1 Reply
03.jpgHello,
i want to ask about why everything in rendering appears blurr , the cushions and the chair legs .. something wrong and i dont know what..
and also 3d max appears an icon that contains this massage:
An exception occurred while rendering with 3ds Max.
This render will abort. If you render again without resolving the exception, you may experience instability.
Unknown Exception
1 REPLY 1
miledrizk
It's not easy to know why from this screenshot but we can do some tests:
1- check to see if your scene is too far from the origin (0,0,0),
If this is the case, bring everything as close as possible to the origin,
A quick way is to make a group out of all objects and move them to 0,0,0
2- If the above doesn't help(of course don't bring them back to where they were if they were too far from the origin)
Then maybe you have some corrupted geometry in your scene. In this case, open a new Max scene, use the Merge
Tool, and start merging small groups of objects(one by one if you can), and with every Merge try a test render
Using the same rendering settings. If all works out, Save the file, then merge another group of objects and repeat
The process until you catch the problematic geometry.
But before trying the 2nd suggestion, try rendering the scene without the vegetations and see what happens.
Some vegetations, like house plants, have VrayFur applied to them, so delete those VrayFur objects
And try rendering to see if it makes any difference.
VrayFurVrayFur
There are maybe other reasons, but let's start with this for now.
miledrizk@gmail.com
3DS Max 2021, V-Ray 5.2
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
My YouTube Channel http//www.youtube.com/c/MiledRizk
