3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
How to model a tubular object with desired skin width?
1 REPLY 1
406 Views, 1 Reply
This is a follow up to a previous thread:
     Translate How to convert a cylinder into a tube?
I am trying to learn how to make a semi-hollow tube or cone.
What I have so far is this: create cone, convert to editable poly. Next, I remove the top and bottom "lids". The "skin" has zero width. I would like to make it a little thicker.
TIA
1 REPLY 1
Put a shell-modifier on it. Adjust inner/outer amount.
**Bow down before shell- modifier** hallowed be his name, solution to so many modeling problems.
