i want to ask about why everything in rendering appears blurr , the cushions and the chair legs .. something wrong and i dont know what..
and also 3d max appears an icon that contains this massage:
An exception occurred while rendering with 3ds Max.
This render will abort. If you render again without resolving the exception, you may experience instability.
Unknown Exception
It's not easy to know why from this screenshot but we can do some tests:
1- check to see if your scene is too far from the origin (0,0,0),
If this is the case, bring everything as close as possible to the origin,
A quick way is to make a group out of all objects and move them to 0,0,0
2- If the above doesn't help(of course don't bring them back to where they were if they were too far from the origin)
Then maybe you have some corrupted geometry in your scene. In this case, open a new Max scene, use the Merge
Tool, and start merging small groups of objects(one by one if you can), and with every Merge try a test render
Using the same rendering settings. If all works out, Save the file, then merge another group of objects and repeat
The process until you catch the problematic geometry.
But before trying the 2nd suggestion, try rendering the scene without the vegetations and see what happens.
Some vegetations, like house plants, have VrayFur applied to them, so delete those VrayFur objects
And try rendering to see if it makes any difference.
There are maybe other reasons, but let's start with this for now.
