3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
How can I do this with 3ds MAX?
8 REPLIES 8
Message 1 of 9
660 Views, 8 Replies
This is something I need all the time and I have not found any easy way to do this in Max.  Can someone help?
Extend face (software: FormZ)Extend face (software: FormZ)
8 REPLIES 8
Message 2 of 9
leeminardi
I cannot think of an easy way but here's my first try.
With snaps set to Edge/segment create a line along each edge that want extruded (red lines). Now move these lines along their edge and then create create a closed line between the 4 line ends (blue line).  The closed spline can then be extruded to the correct thickness and unioned.
Not simple but it works.  A simple script could simplify this process a bit.
lee.minardi
Message 3 of 9
leeminardi
in reply to: leeminardi
I created the following simple script to simplify the process I outline above.
Run the script after creating the 4 vertex red line to get the closed green line.
--  A 4 vertex colde spline is create from a selected 4 vertex spline such that
-- a new vertex is create in line with vertices 1 & 2 (e5) and 3 & 4 (e6).
-- The distance from e2 to e5  = e1 to e2.
-- L. Minardi  1/11/2019
for spl in selection where classof spl == line do (
s=1
e1 = getKnotPoint spl s 1
e2 = getKnotPoint spl s 2
e3 = getKnotPoint spl s 3
e4 = getKnotPoint spl s 4
v12 = e2-e1  -- vector from vertex 1 to 2
vlen = length(v12)
v12u = v12/vlen  -- unit vector
e5 = e2 + v12u*vlen
v43 = e3-e4
v43u = v43/vlen  -- unit vector
e6 = e3 + v43u*vlen
local sp = splineShape()
addnewSpline sp
addKnot sp 1 #corner #line e2
addKnot sp 1 #corner #line e5
addKnot sp 1 #corner #line e6
addKnot sp 1 #corner #line e3
close sp 1
updateShape sp
select sp
lee.minardi
Message 4 of 9
aslantamjidi
A little explanation on Video...
Message 5 of 9
aslantamjidi
And here if our parts are completely  separate Objects...
Message 6 of 9
Thank you very much for the reply.
I was hoping for something that did not involve so many clicks as this is a repeating task in some of my projects.
Message 7 of 9
in reply to: aslantamjidi
Thank you very much for the reply and the time you took to explain your solutions.
I have been using the quickslice tool in almost the same manner as you described, but I was hoping for something that did not involve so many clicks as this is a repeating task in some of my projects.
Message 8 of 9
Hey,
may I ask you first for what you need this "all the time"?
Because to me it doesn´t seem to be something many modelers would use all the time.
Also I would like to know if your final result should be connected or be 2 different objects/elements?
Message 9 of 9
Here a video about the solutions I would use. Hope it helps:
https://drive.google.com/file/d/1epaMC1_yJLQweqCvjj9yZK5qYzf2uXdj/view?usp=sharing
About a mistake in the video: It´s transformation coordinate center of course and not system
Technology Administrators
