3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Help relinking images
7 REPLIES 7
Message 1 of 8
PAarchitects
528 Views, 7 Replies
I am trying to learn 3ds max
I have this sample, but when rendering with vray it is rendering the shape as bright yellow light.
but it needs to show like as fireplace as the following image
fireplacefireplace
if someone could explain to me how to get to this image I would appreciate it.
if can point me to a tutorial , or better make a simple tutorial to explain it to me
thanks
attached 3ds max 2025 and images
7 REPLIES 7
Message 2 of 8
RobH2
in reply to: PAarchitects
I can probably help you with this but I need the maps to do so. You uploaded the Max file but none of the requrired image map files.
Missing:
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
Message 3 of 8
PAarchitects
in reply to: RobH2
thanks
attached fire 2 images
Message 4 of 8
PAarchitects
in reply to: RobH2
thanks
attached fire 1 images
Message 5 of 8
PAarchitects
in reply to: RobH2
also I would like to learn and understand how to make that fire image transparent for rendering
thanks
Message 6 of 8
RobH2
Let me play with it and I'll get back to you. Thanks for uploading the maps.
What version of Max?
Rob Holmes
Message 7 of 8
RobH2
See if this helps. My video got a little long so I had to compress it a bit more than usual to keep it under the forums small file size limit. I hope it's not too blurry for you to see what I'm doing.
FYI, the reason the VRay Exposure Control wasn't working was because I was in a Perspective Viewport instead of in a Camera Viewport. If in a Camera Viewport, those settings will help control the camera's exposure.
Rob Holmes
Message 8 of 8
PAarchitects
in reply to: RobH2
thanks. !!
Perfect !!
I'll be back if I have some other question. 🙂
Technology Administrators
