3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Creating a curved face
2 REPLIES 2
1661 Views, 2 Replies
Hello.
I'm trying to create a curved polygon in the gun I'm modelling but so far everything I've tried failed to achieve the desired effect. Soft selection failed completely for me. I am new to this as well...
Bend Modifier
The point is to make a seamless curvature without affecting the top and bottom edges of the model like so... but without extruding them...
Any thoughts, please?
Thank you.
~S~
Hello.
Bend Modifier
Thank you.
~S~
2 REPLIES 2
blakestone
blakestone
I am not aware of an inbuilt tool which does this however you can do this as shown below:
1. 3D Model
2. Select the 2 outer edges and using the CONNECT tool create some new edges
3. Select this section and detach as a separate 3D Model
4. Add the FFD 2x2x2 modifier from the Modifier List
5. Select both bottom-corner Control Points and you can freely create your rounded curve
6. To get an accurate curve I created a reference square snapping each corner of the detached 3D Model
7.  With the snap tool on select both top-right Control Points and drag down to the bottom-left - creating a perfect curve
8. Re-attach the curved 3D Model and Weld the vertices
9. Re-add the deleted side faces - done
Hope this helps!
Technical 3D Graphic Artist
Autodesk 3dsMax 2015 - Service Pack 4
1. 3D Model
Hope this helps!
in reply to: blakestone
Many, Many thanks! This is a very good solution and you even included a step by step guide! 😄
Thank you very much))))
