3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
HELP! Problem with the Image references on 3DS Max 2017 how can I do it right?
2 REPLIES 2
578 Views, 2 Replies
Hi! As you can see that I'm still new here. And yeah I need help on how to set up this Image reference correctly. So I bought the newest Version of 3DS Max that is 2017. Many people said it was easier to use so I bought it...Yea its easy to use but the problem is this one...I set up the texture and here it is...
And when I zoomed it look like this...
Any help would be very appreciated thank you...
2 REPLIES 2
leeminardi
leeminardi
Try selecting the plane and then go to the Modify panel and verify that you do not have Real-World Map Size checked for the object (which is independent of having it set for the material).
If all else fails you can always add a UVW Map modifier and fit it to the plane.
~Lee
lee.minardi
~Lee
lee.minardi
in reply to: leeminardi
Hi! Thanks a LOT! I've been trapped for month with these problem! I should've uncheck the Real-World Map Size when I'm started to make the reference!
YOU'RE A LIVE SAVER!!! Once again thank you very much!
