I want to model human teeth. I started modelling but the verticles don't complete my shape . I want it to complete the shape. I am beginner. Please help. Thank you.
Solved by ads_czechoj. Go to Solution.
Hi alptekin1998, there are many different options to finish your model. One of them would be to use an editable poly tool in its border subobject: "Cap". After selecting the border of the open polygons, the cap will sealed it. After cup creation, you can turn the Snap tool ON (the main toolbar/Snap) - press "S" to activate it. Right click on the toggle button and choose the Vertex in the dialog. Now you can use the Cut tool from the editable poly tool-set to connect some vertices with edges. This way you will have more control for the shape you create.
Thank you for your answer sir. I think i can not do what you say. It doesn't work. (Probably my fault)
