3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Cannot import model from 3Ds Max into Maya, but only primitive objects.
2 REPLIES 2
491 Views, 2 Replies
I tried exporting files from 3Ds Max into Maya, but whenever I open Maya and try to import files, it does not display anything in the scene, however if I export primitive object into Maya, it displays in the scene. I tried using Game Exporter, whenever I try to send files to Maya, it either shows nothing or "Connecting to Maya" (Maya does not respond).
I am just a beginner, so I might make some mistake, but I want to know where exactly I messed up.
2 REPLIES 2
Daf
FBX is a bit of a picky format - below is a link to some info on non orthogonal matrix errors:
https://www.google.com/search?q=non+orthogonal+matrix+support+fbx
Sometimes this is simply fixed by resetting the x-form - especially if you have done any non-uniform re-scaling, etc.
https://www.google.com/search?q=3ds+max+reset+xform
I believe the FBX import will work fine once you fix the non orthogonal issue but in the mean time you might try exporting from Max as .obj and see if that works better.
Daf
3DS Max 2020.3
i7-4790 @4GHz • 32GB • GTX 1080/8GB • Windows 7 Pro
in reply to: Daf
Okay, I will try this also, but with another model when i tried exporting it I did not have any non orthogonal matrix errors, Maya could not still open FBX or OBJ files imported from 3ds Max, but I could open files from Mixamo... I also downloaded bonus tool, it didnt help.
