3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Blueprints rotate
2 REPLIES 2
536 Views, 2 Replies
Blueprints rotate
Blueprints rotate so it uses the length of the plane for the width of my image any ideas how to fix this?
I have the exact right sizes for the plane
2 REPLIES 2
Fadhil_Farook
1. Apply a UVW modifier and adjust it's settings to fit the image.
    then:
       a. Choose ; PLANAR for Mapping method
       b. Under alignment> Bitmap Fit and choose the image that you're using (See Attachment_1)
2. Apply an Unwrap UVW modifier and adjust the Plane's UV's to fit the image.
If the above answers aren't the solutions you're expecting, can you please provide an image/screenshot of scene and then highlight your problematic areas? That would certainly help resolve any issues.
Irshad_Shah_3dArtist
Hi Friend there are many ways to solve this.
(1) Rotate the image 90 degree in w in material editor.Blueprints rotate.jpg
Or
(2)Apply uvw map modifier and select the gizmo and rotate it 90 degree.
Thank you.
Technology Administrators
