3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
3ds Max 2014 conform tool doesn't work
6 REPLIES 6
3611 Views, 6 Replies
Hi guys, i'm using 3ds max 2014, i'd recently installed it, and i've problems with the "conform" tool in the graphite modelling tools. i select the mesh i want to draw on, but the tool doesn't fit my mesh how i want, it just move it around the viewport with no sense. Iwas working in 3ds 2012, and it never happend, so i would like to know what could be the reason for it, and how can i fix it.
thanks
6 REPLIES 6
had the same issue recently i just made sure i had a high poly mesh but all seems to work fine afterwards
I am having a similar issue with 3ds Max 2014.
If I attempt to conform a plane onto a sphere, the plane pushes through the sphere as if it is not there.
Any help would be appreciated. I'm probably doing something incorrectly.
It appears this is a bug with 3ds Max 2014.
Using the same exact workflow (Freeform Conform) I was able to conform a plane to a sphere in 3ds Max 2012.
However in 3ds Max 2014 the plane passes through the sphere as if the sphere is not present.
Conform tool works with service pack 2 but doesn't work with service pack 3 !!
Yeah, the tool is bugged. However, what works for me is, to switch between conform and conform-move one time before actually painting the conform. It works...
Click conform, then click conform-move and than switch back to conform again... it works...
Ahah, this is a strange way to make it works, but it works well... thanks a lot !!
