problem 3d max 2018,can't see the red line,proboolean
hdcboy
Message 1 of 18
hdcboy
Replies (17)
Message 2 of 18
hdcboy
eeeer nobody know?o my god
Message 3 of 18
hdcboy
3dmax 2019 same problemSmiley Sad
Message 4 of 18
hdcboy
2012 Is the right
Message 5 of 18
tony.su
Autodesk Support
Autodesk Support
什么是red line?
下次您发帖可以直接在中文论坛发。
Tony Su
Product Support
Message 6 of 18
hdcboy
The red line is the color that should appear when selecting an edge
for example
Message 7 of 18
tony.su
Autodesk Support
Autodesk Support
Do you mean this red line? Could you try to reset 3ds max?
https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/sfdcarticles/sfdcarticles/Resettin...
Tony Su
Product Support
Message 8 of 18
hdcboy
not this one. In  proboolean the editor,
Message 9 of 18
hdcboy
Wait for the moment to thank you
Message 10 of 18
tony.su
Autodesk Support
Autodesk Support
我觉得很有可能无法显示红色。
我猜测,其实是显示了红色。但在viewport里面显示的是boolean后的物体,压根就没有显示你选择的目标物体。
如下图,我选择的线压根就没有显示出来,因为显示的是最终物体。所以boolean后能改动原始物体仅仅是一个选项,最好不这样做。
Tony Su
Product Support
Message 11 of 18
hdcboy
Bad news, it's impossible
Message 12 of 18
hdcboy
Why is max 2012 normal
Message 13 of 18
tony.su
Autodesk Support
Autodesk Support
Viewport was changed,  I guess some display function were changed too.
I didn't install 3ds max 2012,  so I couldn't test it.
Tony Su
Product Support
Message 14 of 18
hdcboy
max 2016 the same to normal
Message 15 of 18
tony.su
Autodesk Support
Autodesk Support
The results are same in 2016 and in 2018.
Tony Su
Product Support
Message 16 of 18
hdcboy
(proboolean must select operands) Correct steps:
try in 2016 Please
Here are the correct instructions
Message 17 of 18
hdcboy
Celebrate, solveSmiley LOLHeart
There's something wrong with the video card setup
 snipaste_20180713_192539.pngsnipaste_20180713_192623.png snipaste_20180713_195501.png
Message 18 of 18
hdcboy
, but it is flawed.
