How to Path Deform a whole bunch of objects together?
Message 1 of 23
I am building a kind of tunnel. I build one segment of the tunnel and after that I would like to PathDeform the complete tunnel. Unfortunately the tunnel consists of several different objects. So I selected everything and tried to PathDeform everything. But I get weird results. If I try FFD Modifier it works well (except for the problem with bended Arnold quad lights.)
Thanks for suggestions, appreciate the help!
All the best
Kai
( I am not a native English speaker, so forgive me if something is not correct.)
Replies (22)
Message 21 of 23
Sry, thought my Thread was completely dead.
I made that tunnel sequence finally with blender. Mainly because rendering time was much faster.
It was used for a trailer
Message 22 of 23
10DSpace
@Anonymous
Looks good!  Which renderer did you use in Blender and what were your render times per frame and output resolution?
Message 23 of 23
Thanks 🙂
I rendered it witch cycles and it took 15-20 Minutes per Frame.
In Max it was 25 Minutes+ per Frame just for a few tunnel segments and therefor also just a few lights. First I wanted to use Eevee but Eevee can just handle 128 lights and that was too less. I could have animated thje position of the lights but I figured that this animation would have cost me more time than using Cycles 🙂
EDIT: I have an i7-7700K, 32GB RAM and a GTX1080Ti
