Help with show end result
I am trying to modify the vertices of a skinned model. When i activate show end results on the modifiers stack it only applies the skin modifier (which is on the top of the stack) to the verteces i have selected (in the edit poly modifier which is below the skin). Is there any way to modify only a selected vertex in the editable poly and at the same time see how the skin is applied to the rest of the model?
CAMedeck
Add a Poly Select modifier just below Skin.  This will cancel out the sub-object selection of your Edit Poly modifier and allow the Skin modifier to affect your entire mesh.
Chris Medeck
That did the trick! Thank you! 🙂
Thanks a lot. Now I can work in peace without deselecting to see end result!
