Add segments to Revit object
Hello there,
When I create a box in 3ds max it gives me in 'modify' options to add segments and then when I add Turbosmooth I can costumize it. Is it possible to add segments into a imported Revit Object? The reason for that is when I add Turbosmooth in modifier the Revit Object it disappears.
When you import a Revit object, you opt for an editmesh.
You can convert it to editpoly
An Editpoly or an Editmesh, you can "add" the edges with the connection
However careful, everything will depend on your original object! If the object is curved for example!
You also have to check your import file! If it's an RVT or if you went through a Revit export to a DWG! The curved elements will not have the same mesh !!
