Twist modifier needs to be updated
A simple task, you need to rotate the object in a certain place by a certain degree. The "twist" modifier doesn't allow me to do this, and the "limit effect" options don't help. In Cinema 4D, I can do this easily and simply in a couple of seconds with the highest accuracy. The "twist" modifier in 3D Max needs to be updated so that it can handle any given task like in Cinema4D.
6 Comments
hwoRX6FJ
Situation with the "bend" modifier is similar compared to Cinema4D
shawnolson
If I am understanding your request, this is already available. Please refer to this video: https://knowledge.autodesk.com/community/screencast/22354136-a226-4e07-9ab3-f0578455b557
hwoRX6FJ
Thank you for the answer, but this method is not the same as I showed. When I using "limit effect", the set angle is also cut off. What makes "limit effect" unusable if you need an exact degree of rotation. In Cinema4D, when I change the gizmo area, the angle I set doesn't change.
shawnolson
OK, I think I might understand your request a little more. Are you saying that with limit effect on, you want the exact angle to be reached within that limit?
shawnolson
hwoRX6FJ
Yes, you got it right. The same goes for the "Bend" modifier too.
