Plane primitive - Option to specify length and width of sub-quads
Hi!
Can you please add an option to enter explicit values for the lenght and the width of the sub-quads of the Plane primitive? As an alternative to the existing "lenght and width segments count"-method. So that we don't need math or script to create a plane with accurate measured sub-quads.
Ex: I want a plane, which I create by mouse drag as usual, but where all sub-quads are 50cm x 50cm or 20cm x 60cm. Then if the outer borders of the wohle plane don't fit exactly into that measures, they will be clamped to fit (or optionally stay, sized depending on the remaining diffrence).
This would be super useful when you need to work with accurate measures and for shared parameters workflows.
Thank you and greetings.
1 Comment
any software that does this already?
