Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Include a speed controller.
Please include a speed controller for 3ds Max.  To Animate an object by RPM.
I have two different solutions at the current time.
One solution is here.  https://forums.autodesk.com/t5/3ds-max-forum/animate-with-the-hidden-speed-controller/td-p/4290247
The other one is http://forums.cgsociety.org/showthread.php?f=98&t=497415&page=2&pp=15
The Later one works well.  The Particle concept does not work well at all.
Thanks for taking into consideration.
4 Comments
nauh
I don't know your exact needs but maybe this could help you
RPM controller
http://www.scriptspot.com/3ds-max/mcg/mcg-rpmspin
BPM Controller
http://www.scriptspot.com/3ds-max/mcg/mcg-bpm-float-controller
electrotoast_old
sdeters
What I need is to speed up a object and slow it down.  Infinite Variable speeds is what I am needing at this time.  Imagine a car going from a stop to full speed then slowing down.  Then going into reverse.  The propeller example in my list works great.  The Speed using particles does not work well due to flashing and jerking objects at zero speeds.
sdeters
If this does get any traction, the solution must work when rendered over backburner or network render.
