This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Intersection Snap
Intersection Snap
Come on Autodesk - the "Snap to Intersection" has to be included in this expensive, mature piece of software !!!
13 Comments
electrotoast_old
Indeed this is probably the feature I miss the most in 3ds Max. Even better would be to implement it similarly to what Sketchup or AutoCAD already have - i.e. being able to snap to intersection and also to an apparent intersection(but in 3D space as well, so it would work with vertices, edges and faces). I think such feature would be a huge speed improvement in modeling workflow, especially in archviz. Imagine the possibilities with Cut,QuickSlice or Extrude capable of using snap like that.
JezEmin
Where is this implemented ?????
This is the 2nd suggestion of mine which has been marked as implemented, yet that is NOT TRUE !!!!
I really miss this function
the question is... is it really possible that this function DOESN'T exist...
Unbelievable, this is such a needed feature!
I commonly run into scenarious where this would help me out greatly, but there's just no way.
I end up having to either eyeball it, or come up with a workaround (like tweaking the "connect" tool when I know how many percent along the edge the intersection is).
Surely, there has to be a simple and reliable solution for this!
This is a very common use case for me in re-topology, or modelling from floor plans, or just for fixing mistakes.
also what is wrong with Snap to Center Face? why does the Poly are split into triangles and snapping happens to center of the triangular face ?
JasonLuckett
How's this hasn't ever been incorporated is pretty remarkable, considering there are requests over 20 years ago. Unfortunately it goes to show how little users are considered. Snapping should of moved on a great deal from this basic clunky snap we have in here.
anyone knows how the other 3d packages support this?  but Max should be the lead whatever the case
Well, I can't say how the other software packages(like Sketchup for
instance) support such robust snap features internally as their source code
is most probably pretty low-level and therefore not accessible. However,
recently I've been learning Maya and I consider it's implementation of
Snap(along with it's equivalent of Working Pivot that can be easily and
quickly oriented and snapped even to sub-object selection) so much better
and more pleasant to work with.
Besides that, with Multi-Cut tool in Maya you can snap either to adjustable
fractions of the edge you're cutting / perpendicularly from the edge you
started your cut from(or towards another edge you want to cut next) / or
you can even continue your cut along that edge's direction(but only on
already existing surface). While it's not as powerful as Sketchup's Draw
tool with it's full-3d(and almost CAD-like) inferencing system and
autoweld/make polygon function, I consider it pretty huge improvement over
Cut tool in Max that also feels like it has been forgotten long time ago.
It should also be probably pointed out that Multi-Cut in Maya has the
functionality of Max's Quick-Slice, Quick Loop and Connect with Edge Flow
tools built-in and easily accessible by pressing modifiee keys like Shift,
Ctrl... . Most importantly however, in comparison to Max's Cut, Maya's
Multi-Cut rarely "misses" when cutting your geo, whereas in Max it often
fails to cut even pretty straight-forward topology.
I realize that Snap(and maybe Cut too) source code probably "sits very
close" to the implementation of how Max works with vertices, edges, polys
etc.(i.e. the core stuff, which probably also is pretty ancient) and
changing/reworking it could potentially cause a lot of new issues, but I
think it is high time to start working on it if Autodesk still want to sell
3ds as the prime tool for archviz.
And, apart from overall neglection, Snap also seems to be falling behind in
performance. Just try working with it in a polygon-heavy scene(which almost
all archviz stuff is nowadays) - often it can make even simple things like
zoom unbearably slow, especially when you have your scene almost finished
but you have to change something in the last moment.
Autodesk owns both Maya and Max so if not anything else they at least have
a template how it could be done.
Now that you are working  Snaping Pivot worth checking these stuff out as well!
JasonLuckett
The fact that no-one from Autodesk chases these issues up says everything. Try most other software forums and you would have an active dialogue with an employee / developer trying to help. Silence speaks volumes.
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
