Improved UV Editor (Including Automatic Unwrapping and other Maya features)
Hello, everyone! I've been using 3DS Max as my primary driver for 3D modeling for quite some time, and I noticed the UV Unwrapping tools feel rather outdated and barebones compared to what recent versions of Maya have to offer, which has lead to frustration several times due to some issues that I've faced regarding getting decent UVs that don't have distortion or overlapping issues by attempting to do everything manually. As of right now, for example, for automatic unwrapping, you have to bring your mesh into Maya (or even non-Autodesk tools such as Blender), generate the UVs and then make changes to the UVs in that software before exporting it as an FBX and bringing it back into Max. Either that, or use third-party plugins, which either haven't been updated in a long time, or that cost extra on top of the 3DS Max license (Which is similar to how the Unity Engine has worked regarding said functionality for a bit). Having some sort of tool that could fix UV distortions with stuff such as very short cylinders and other things of the sorts could also be useful.
To cut to the chase, the tools that are included with Max for this functionality could be a bit more beginner friendly, to allow more room to hit the ground faster before adjusting and polishing said UVs. Thanks for reading, and apologies if I sound a bit critical.
3 Comments
for the UI part at least Ive made a well illustrated idea some time ago hinting at the more decent design of Maya one
[UV Editor ] A more clean, tidy and fresh UI like the new Maya one - Autodesk Community
One of the reasons the new UV editor and UV toolkit in Maya look way better its because was inspired by a cool third party plugin and this is obvious. It just looks so fresh. Packed with features, carefully organized, proper spacing etc. Max one only got new icons with the new releases but nothing more. Max needs to update its style and reorganize its layout already !
gandhics
What's Maya's Automatic Unwrapping?
they added Maya algorithm but definitely the UI needs a revamp
