Grid Slice Volume
Grid Slice Volume
Need an fast and procedural way to cut a mesh into multiple even segments.
An option could be a function in the slice modifier to cut/slice to a grid with a number of slices in x,y, and z. Same way you add segments to a box.
See Modo's Axis Slice for reference.
https://youtu.be/bszVn3XfmAY
https://youtu.be/iizh0q6hN1Y
2 Comments
is that the actual slice from 3ds max?  has an option to remove the parts as well?
Swordslayer
If you want it now, you can use the free version of KeyHydra, it has Volume Slice modifier that does that.
