Better wire/controller access from command panel.
If I create any controller on any parameter on command panel, or I wire a parameter, It gets grey and its impossible to edit anymore from comand panel.
Example:
Create a box, On curve editor, choose Height, and add a Noise controller.  Now your Height Box on command pannel is grey out. You can not access the noise controller from here anymore. You need to acces the noise controller from the Curve editor.
Ideally I will like to double click or right click or something to edit easily this noise controller from my modifier panel.
2 Comments
bigonethegod
Tool and UI like Xpresso from cinema4d would be great!
brentscannell
