Within the batch rendering window the ability to:
Select all
Select none
But also to be able to assign a layer per job, so that when the batch starts for the selected jobs it only shows/renders the layer assigned to it.
I have a scene with 45 layers and a camera in each layer and i need to render all of these out, but without the ability to render only a certain layer i have to do this manually which means i can't run the whole batch at once. I have to run the batch for a layer, hide that layer and then show the next one and run the batch.
I know there are other ways of doing this such as moving the objects into view when needed using keyframes etc, but my scene is huge and i depend on the layer system to organise everything so it would be nice to have that built into the batch render system so i can render all my layers out without having to manually assist the process.
