I install my 3ds max 2017 and vray, and from the start have problem when I put my vray sunlight into the scene.
MY RENDER IS TOO BRGHT!!!
I try with many vray settings and nothing helped me. But, when I render my older projects, it render it perfectly.
Please give me some solutions.
Solved by photodave. Go to Solution.
Are you using a camera view when you render? If you render in say perspective view then yes it will blow out the scene a lot, but if you use a camera then you can control your exposure settings and bring the scene down to where you want for over all exposure.
What version of 3dsmax and V-Ray are you using?
*EDIT*
If you are using a physical camera then try in the camera properties in the modifier panel click the buttons that says "Install Exposure Control", set manual ISO to 100 and up above that in Shutter settings I set mine type to "1/Seconds" and a start duration of 500 and go up or down from there depending on how bright or dark I want the scene.
Since there no more physical cameras in 2017 you have to use Exposure. I'd suggest using the Vray frame buffer and you can adjust it there. Also you'll get better answers on Vray stuff in the Chaos Group forums.
@Anonymous wrote:Since there no more physical cameras in 2017 you have to use Exposure. I'd suggest using the Vray frame buffer and you can adjust it there. Also you'll get better answers on Vray stuff in the Chaos Group forums.
While there is no "V-Ray Physical Camera" any longer, there is a "Physical Camera" in 2017 that has exposure control.
Hello @adamk, @Anonymous, @photodave,
I was going to mark some posts in there that obviously helped solve this for @Anonymous. I also wanted to add that you can get Vray cameras of old back with the command vrayCreateVRayPhysicalCamera().
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
