When I export an STL object from 3DS max the object changes scale from inches to mm in other 3d printing software. I am creating models that I can print with my local XYZPrinting software. I am using 3DS Max 2020 student version and exporting files to .STL. (1) I only have ONE object. (2) 3DS is set to use inches: unit setup > inches (3) The object dimensions (in inches as shown in 3DS) System Unit Setup is in inches as well. (4) The STL check modifier in 3DS tells me there are no errors. (5) I export the object: 3DS > export > .STL (a window pops up with very few settings) I tried ASCII then BINARY. I tried to tick and untick "selected only". However, everything leads to the same conclusion (auto-converted from inches to mm). (6) When I import the file with other software, the object's dimension is again in mm.
Any assistance would be greatly appreciated.
TYIA, Kevin
Can you confirm if the STL comes back into Max itself in inches or millimeters if you re-import that exported STL into Max?
After asking around, I learned that the STL file format does not contain any unit data stored in it. See if your printing software has some setting for units upon loading the file. You may be able to designate the scale of the file in your target application.
