Message 1 of 8
03:26 AM
Hi, Here is my question, background, context and settings hereunder: How can I export an STL object which keeps its same dimension as in 3DS max ?!? Context and background: I am trying to create models that I can print with my local fablab. I am using 3DS Max 2015 and exporting files to .STL. According to fablab I need to use "ascii" export and not "binary", however I did try both but with the same result: 1) I only have ONE object. 2) 3DS is set to use mm: unit setup > metric > millimeters 3) The object dimensions (in mm as shown in 3DS): 232x85x8 4) The STL check modifier in 3DS tells me there are no errors. 5) I export the object: 3DS > export > .STL (a window pops up with very few settings) > object name: Object01 > ASCII > Selected only > OK Note that I also tried to use a different name than Object01? I tried ASCII then BINARY. I tried to tick and untick "selected only". However every thing leads to the same conclusion. 6) When I import the file with netfabb the object's dimension is: 9,13mm x 3,35mm x 0x31mm When I import the file with netfabb the object's dimension is: 9,13mm x 3,35mm x 0x31mm Now the funny thing, if I set 3DS up with: customize > unit setup > US standard > decimal inches. I notice that the object dimension are 9.13 x 3.35 x 0.31. Which is the size of my object IN mesh mixer and IN netfabb, only with mm instead of inches... Some coder ****ed it up somewhere. I have seen numerous post on forums with people struggling to export STL files and "keeping" the dimensions. I am speaking about different softwares here. However I could not find any good resource on the subject for 3DS max and I am CERTAIN that some people wanted to create models to 3D print afterwards and struggled with the STL export as me :(. I could **not** transpose any solutions given in these post as they refer to some settings that have to be configured within the STL export plug in. 3DS STL export plug in only has the settings that I listed above. I also tried changing the units of 3DS. Same result :(. Please help meeeeee I am going crazy. Yours, --Jay
