3ds max file lost
3ds max file lost
Need help urgent:
My program suddenly close without any warning. The file I'm working the whole has no where to be found even in autoback folder. Is there any way i could retrieve may file? Any other folder it might be? Thanks a lot
irishman_team_kilber
To my knowleage the files don't automatically delete themselves, unless someone delete it have you check your recycle bin if it's there then you can just restore the file,
if it not there. try using searching the run box type in the name of the file and if it's in windows then you can just place it back in your autodesk scene folder.
with the auto backup autodesk automaticaly over-rides the file when you start a new scene file,you should also use the save as + sign this save your file increments but you will need to keep over-writing the increment save which can be annoying but this is a advantage max will not over ride increments  file,
RobH2
Did you save the file at least once? Was Autobackup set to run? If the answer is "no" to both, then the file is gone. But if either of those were done, you should have a file there somewhere.
You should have a folder listed in the screenshot I attached. See if there is a file in there.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
darawork
Also worth checking your project folder. Check the 'User Paths' settings. Look at the top of the box for your chosen Project path. The Autoback path is relative to your Project folder. It's not an absolute value, E.g. It moves location depending on your Project folder.
I've seen cases where people have recovered Autoback files from very unusual locations, and sometimes those paths that are hidden from the standard windows search locations.
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
jon.bell
Hi @Anonymous ,
Just reviving this thread to see if you'd been able to recover your original file, and if there were any other suggestions we could offer to you. Could you please let us know? Thanks!
Jon A. Bell
Senior Technical Support Specialist, 3ds Max
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
