Solved by jon.bell. Go to Solution.
Good afternoon, if you want to change the colour of the faces of the object, you can try selected the objects that you want to change the colour on it first, next go to the Modify (at the right side panel) ,choose the 'Edit Mesh', and select the 'Faces' which under the 'Edit Mesh'. Then select the faces of the object and apply the colour on it.
Hi @Anonymous,
Shaded objects in 3ds Max viewports can show either (applied) Material colors or Object colors, as set by the Command Panel > Display tab.
You can change the Object color of any object by right-clicking on it to bring up the Properties menu and then changing the color assigned to it.
To assign random Object colors to all selected geometry in your scene, please see this article, and let us know if this helps!
Hi @Anonymous ,
Just wanted to check back to see if the information I posted above has helped. Could you please let us know? Thanks!
