Turn off docking?
Turn off docking?
Message 1 of 13
Turn off docking?
Is there a way to turn off docking on certain floating panels (e.g. the new Layer Explorer)?
I'm not dealing with a lot of screen real estate on an older Cintiq 21UX, and would like to just temporarily move a window out of the way so I can see the viewport beneath it.  However, when I do, I get even less screen space for the viewport, because the docked window now takes up 1/3 of my screen.
This is a rather annoying issue, and slows down my workflow.
Replies (12)
Message 2 of 13
Click on the line on top of the toolbar, look at my print screen, drag the window out of docking and close it.Capture.JPG
Message 3 of 13
Hi Eric,
Thanks for the reply.  I'm actually not looking for how to undock a panel.  I have it floating already; and sometimes, when I want to just move it out of the way really quickly, it automatically docks to the side.  I'd like to be able to move it (e.g. over the Command Panel on the right) without it docking automatically.  In other words, I'd like floating panels to remain floating panels no matter where I drag it unless I explicitly tell it to dock.
Thanks!
-Chris
Message 4 of 13
spacefrog_
There is an easy way for this:
Activate "Lock UI Layout" in the "Customize" menu. As long as this is active, dragged windows don't dock.
You still can undock/dock them using the RMB menu in the titlebar of the dialogs/toolbars then...
Josef Wienerroither
Software Developer & 3d Artist Hybrid
Message 5 of 13
Awesome! This is exactly what I was looking for! Thank you so much!
Message 6 of 13
JezEmin
I'm on 3DS Max 2019.3 and this does not work for me.
I move the Scene Explorer a lot and it is INCREDIBLY frustrating that each time it wants to dock someplace on the interface.
Please can you advise ?
3d rendering services
Asus X299-SAGE, 7980xe @ 4000mhz, Corsair Hydro H150i Pro,
1Tb Samsung M.2, 128Gb Corsair LPX DDR4,
2 x Nvidia RTX 3090 FE,
3DS Max 2023.1 (3DS Max 2022.3, 3DS Max 2021.3 as backup)
Windows 10 Pro.
Message 7 of 13
brentscannell
Hi everyone,
There is a known issue in 2019.2+ where the scene explorer and track window don't respect the lock UI setting, we apologize for that and are looking at solutions.
There is also a little known trick with respect to docking: if you hold "control" before dragging a window, it won't try to dock anywhere regardless of what you have in your lock UI settings. You need to think about it before you move, though, because if you hold control after you've grabbed a window it won't block the docking behavior.
Message 8 of 13
brentscannell
I just did a quick check and one of our users in the community just started an idea about making auto-docking a preference, instead of having to press control.
Cast your vote here:
https://forums.autodesk.com/t5/3ds-max-ideas/please-make-an-option-to-prevent-automatic-docking/idi-...
Message 9 of 13
I just started to work with 3dsmax2020 and I want the autoDocking disabled.
Lastnight I had vpn+vnc from my home to my work computer and I moved the Layer explorer-window,
it docked and I couldn't remove it. Just now wanted to learn more about this docking-thing, found out
about the CTRL+move > will not dock, that sounds to me sooooo useless. Yes it works but still.
Also the Lock UI layout isn't doing absolutely anything. It is on, I assume "locked", but it still lets me dock.
And I really don't want that.
Message 10 of 13
DanielCantin
Hi @Anonymous
This issue has been fixed in 3ds Max 2020.2, sorry about the inconvenience and thanks for reporting, I suspect you are using a earlier version, if not please let us know.
-Daniel
Daniel Cantin
QA Manager, 3ds Max, Maya
Entertainment Creation Products, ECP
Message 11 of 13
Torsion_jo
Observer
Observer
Thanks A lot Great Man!!!!!!
Message 12 of 13
sharadtwi
Community Visitor
Community Visitor
Thank You so much .
Message 13 of 13
MartinBeh
FYI, here is a tiny macroscript (save as .mcr, then execute, then find the new "mb_LockUI" action under "MB Tools") that you could assign to a hotkey to toggle the UI Lock on/off:
macroscript mb_LockUI
category:"MB Tools"
	max lock UI layout		-- Lock User Interface Toggle
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
