Since 3dsMax moved to Qt, everytime when I move floating dialog, 3dsMax is trying to dock the dialog automatically.
This is really annoying for many users.
in 2019, you can press CTRL to prevent dock.
But, default behavior should be reverse, docking only when you press CTRL.
Either reverse the behavior or give us an option to set the behavior.
LockUI doesn't help either because you can not even resize Se or TV if you lock UI.
