3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Tablet Problems
1 REPLY 1
support2nd
426 Views, 1 Reply
Tablet Problems
Product Name : 3DS MAX 2019
Version : 2019.3.4Security Fix
OS : Windows10 20H2
Pen Tablet : Intuos Pro (PTH-660/KO) : Driver (6,3,35-3) version
I've bought a new pen-tab and the only problem I'm having is when I start 3dsMax, the pen-tab responds even when I lift the pen-tip, so it rotates and the view screen spins around.
When I contacted Wacom about this problem, they told me that if the problem is only with 3dsMax, I should contact Autodesk.
Also, the reason why it is not the latest driver (6.3.41-1) is because when I first installed 6.3.41-1, the pen-tab did not respond and Wacom recommended 6,3,35-3. Since then, it has been working fine (even Photoshop responds fine), but for some reason, the pen-tab does not work properly only when using 3dsMax.
Restarting the computer did not help.
Also, I don't use any other pen tabs, so it doesn't seem to be a driver conflict issue.
Please provide any information you may have.
Labels (1)
1 REPLY 1
in reply to: support2nd
to my knowledge most Tablets are meant to be used on 2d programs like photoshop.
i have never seen them work with any 3d program unless they are the expensive  ones that are compatible tablets.
here is one thread about the Wacom Intuos To Wacom or Not to Wacom
