Swift loop doesn't work.
Svetoslav.Tabakov
Message 1 of 8
Svetoslav.Tabakov
I have a bunch of installs ,2026, 2025, 2024, 2020) and swift loop doesnt work in any of them.
I test on a standard cube converted to edit poly. the swift tool (which i use constantly) turns on from the ribbon, the mouse cursure turns into a star (as is should) but I can't place a loop. No preview, no actuall edge if i press arround and turn the tool off.
I use the tool constantly I know how it works... What's happening ?! It just stopped working in ANY max install.
Tried installing the latest nvidia drivers - no dice.
the only other change I can think of is a recent windows update, but I am on a work computer and can't test removing updates or anything like that.
Some installs have scripts some don't
I tried reseting all settings but didn't help.
Any help ?
Replies (7)
Message 2 of 8
rosie_lucas1
Hi @Svetoslav.Tabakov
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
Rosie | Community Manager
Message 3 of 8
Svetoslav.Tabakov
Yeah, aperantly, the january windows update broke a lot of stuff including elements of 3ds max.
Installling the latest C++ redistributable fixes all of the issues including the swift loop issue.
Thank you!
Message 4 of 8
haifeng_yuSEVKN
hello @Svetoslav.Tabakov and @rosie_lucas1 , thank you very much for the post and information. I am happy to hear the issue was resolved by updating Microsoft Visual Studio C++ redistributables. If you need more assistance in the future, please feel free to share more questions in the forum. Thank you!
Haifeng Yu
Technical Support Specialist
Message 5 of 8
jorisC
Observer
Observer
yes, finally, same here, 3dsmax 2024 and 2026, no swift loop
installed latest C++ redistributable (both 32bit and 64bit to be sure), restarted pc and it is back!
thank you!
Message 6 of 8
moor6588
Community Visitor
Community Visitor
Thank you so much for the help @Svetoslav.Tabakov, I have been struggling for so long with this! I just installed that newest X64 C++ redistributable off of this Microsoft page and it fixed everything: https://learn.microsoft.com/en-us/cpp/windows/latest-supported-vc-redist?view=msvc-170#latest-suppor...
Message 7 of 8
Svetoslav.Tabakov
Glad to help.
Message 8 of 8
paulinhopro7
Community Visitor
Community Visitor
Occasionally, the 3ds Max selection system may freeze invisibly. Please try the following workaround:
Convert the cube to an Editable Poly.
Access the Edge sub-object level by pressing the 2 key.
Select a random edge.
Navigate to the Ribbon and enable Swift Loop.
Hover the cursor over the object. In most cases, forcing a sub-object selection prior to activating the tool restores the preview functionality.
