Strange white box in viewport at startup
studio
Message 1 of 15
studio
When i start, i can see those strange White Box, on the viewport... What's the problem?
Replies (14)
Message 2 of 15
kennyj
Hello Studio!
A little more info would help:  What version are you running, what is your system.  A screen shot of the white box?
Is it specific to a view port (do you have your screen set to 4 views, three or one or other?)?
My first guess is either a hung-start up window, minimize then maximize your screen to see if it clears.
Next guess would be to confirm you have the latest video card drivers.
Next would be to check your resolution; try changing then changing back to see if it makes a difference.
Hope this helps,
Kenny
Message 3 of 15
studio
it is running on Windows 10, 3ds max 2017 regularly udgraded; the box is on top, front, left... (not in 3d views)
when i'll retourn on my PC i'll try and send a screenshot...
tks
marco
Message 4 of 15
-niels-
It's not the viewcube is it?
If it is, you can right-click on it, select "configure" and you'll get the menu shown in the image where you can change it's settings.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 5 of 15
studio
this is the shot, no viewcubeSmiley Surprised
Message 6 of 15
-niels-
Yup, that's not the viewcube alright...
Looks like some geometry from that .rvt file (Revit?) to me, or does it stay in the same location when you zoom?
Have you tried hiding the ziggurat.rvt, anything change when doing so?
I'm still unfamiliar with a lot of 3DS Max, so if it's not something simple like that i hope the experienced people will chime in.
Niels van der Veer
The Netherlands
Message 7 of 15
studio
i've tried with a new blank document, the same thing...
Message 8 of 15
Alfred.DeFlaminis
Hello @studio,
That does seem to resemble the artifacts I've seen when a graphics card is unsupported or uncertified.  Can you please let me know which graphics card you are currently using?  Does this same thing happen in DX9 mode?
Best Regards,
Message 9 of 15
Alfred.DeFlaminis
Hello @studio,
I just wanted to follow up here, any progress on this issue?
Best Regards,
Message 10 of 15
studio
yes, with Direct 3D9 and also Open GL
Always the same!
Message 11 of 15
Alfred.DeFlaminis
Message 12 of 15
kennyj
Okay,
This screen shot helps.  Because it does not take up the full viewport, I am inclined to think this is an artifact from the RVT file that has been inserted.  You said you tried opening a new file; did you open a new blank file and see this white box, or did you open a new file and import the .rvt file again?
I would explore the RVT file and see if you can crop / select on the geometry you need to import.
Hope this helps,
Kenny
Message 13 of 15
studio
Nvidia Quadro FX580
the same issue with a blank documentSmiley Frustrated
Message 14 of 15
Alfred.DeFlaminis
Hello @studio,
Unfortunately the card is unsupported/uncertified.  Smiley Sad   I know that's not great news.  You can find a list of supported graphics cards here.
The only method I know that might work is to try other display drivers in 3ds Max until you find one that might be supported such as Legacy d3d or something like it.
Best Regards,
Message 15 of 15
Alfred.DeFlaminis
