Show shaded mat in viewport button makes objects invisible
Kennet3design
Message 1 of 73
Kennet3design
This happens a lot for me to. Very annoying. I first noticed this in max 2018 but it happens in 2017 also when I checked. To be able to see the textures when this happens i have to change the shading mode to facets instead of default shading.
To fix this I try starting up more max instances until one of them suddenly works. Or close max, delete the enu folder, start max again, open a scene to check if everything is fine which it usually is. Close max again. Then delete the enu folder and use my copied enu folder with all my settings instead and start max again. This works sometimes but not always.
I encounter this several times a week or even per day sometimes.
I never had this kind of problems before. But now om on new hardware and win 10 instead of win 7. Maybe win 10 and max does not work so great?
I have the same problem on both of my computers. They have identical hardware and operating systems though. Soon I will get a new laptop, it will be interesting to see if the same problem occurs on that.
Windows 10 - 64  Gig RAM - Nvidia quadro P5000 with driver 376.33 - Dual Intel Xeon E5 2687W v4 - 512 Gig SSD
EDIT: Posts moved and title updated.  -Alfred
Replies (72)
Message 61 of 73
thank you so much
Message 62 of 73
Diffus3d
Thank you for posting that @luismestre.  I appreciate the confirmation and I'll mark your post as a solution.  Thanks again!
Best Regards,
Alfred
Message 63 of 73
liddilr01
We deleted this file and it worked perfectly.  But then after a reboot of the machine and opening the file back up it went back to invisible geometry.  deleted the "maxFxoCache" and it went back to working.  Our 3D team has to delete this file about 5 times a day which is very annoying.  We have re-installed max and same thing.
Message 64 of 73
liddilr01
We deleted the "maxFxoCache" file and it worked perfectly.  But then after a reboot of the machine and opening the file back up it went back to invisible geometry.  deleted the "maxFxoCache" and it went back to working.  Our 3D team has to delete this file about 5 times a day which is very annoying.  We have re-installed max and same thing.  It seems like when the actual machine reboots we have to re-delete the "maxFxoCache" file every time before we start max.
Message 65 of 73
Diffus3d
Hmmm.  I don't think there's anything about normal rebooting that would change a file unless maybe your IT department has some kind of 'Deep Freeze' or similar program or maybe Windows is restoring a profile on load?  I'm out of my element with that particular topic however, it's not my area.
But if it takes a reboot to cause the problem, it stands to reason that something about that reboot is part of the problem so it sort of points to Windows or some kind of backup software maybe.  Perhaps your profile is loaded off the network?  So you make local changes, but on reboot it loads the profile again off a network machine?  (Or something.)   I'm totally guessing here.
Message 66 of 73
khaled3dmax
Community Visitor
Community Visitor
thank you very much
It's worked out with me and the problem is over
Message 67 of 73
Hi !
It worked for me. Thanks for your support !
Message 68 of 73
hi, i has been reading and follow all the solutions, and its worked by deleted this file ""maxFxoCache" and it worked perfectly.  But then after a reboot of the machine and opening the file back up it went back to invisible geometry.  deleted the "maxFxoCache" and it went back to working.
i read the solution
"Hmmm.  I don't think there's anything about normal rebooting that would change a file unless maybe your IT department has some kind of 'Deep Freeze' or similar program or maybe Windows is restoring a profile on load?  I'm out of my element with that particular topic however, it's not my area.
But if it takes a reboot to cause the problem, it stands to reason that something about that reboot is part of the problem so it sort of points to Windows or some kind of backup software maybe.  Perhaps your profile is loaded off the network?  So you make local changes, but on reboot it loads the profile again off a network machine?  (Or something.)   I'm totally guessing here.   "
but i not sure how to figure it out..can i have details steps to check on it?? Thank You Very much
Message 69 of 73
hagen.deloss
@Anonymous
Thanks for the information! Are you student working off a school computer by chance? School machines may very well have a particular setup that reboots the system profile on startup.
If you are working for a company, I would check with your companies IT department.
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 70 of 73
Ross2006
This worked for me! Thanks
Message 71 of 73
farcasterP8GRF
I'm necroing this because I've run into this same problem with MAX 2022.  Deleting the maxFxoCache.dat file solved it for a day, but after the computer was shut down overnight objects have once again started going invisible.
The strangest thing is that it only applies to one specific texture in the scene.  Others do not seem to fail to display properly.  Is there a permanent fix for this issue yet?
Message 72 of 73
jphoi_91
hi all,anyine solve this issue? i have this problem now on my veiwport configuration,
1.jpgerror.jpgim having it like 2 mos now,i really need help, pls see attach photo & video.. 3d just go crazy wireframe
, it temporarily fix by changing viewport configuration antialiasing quality to 2 or 4 or 0 then comeback the problem, very stressful problem.
thanks,https://www.youtube.com/watch?v=q4Qq3zasYAQ
Message 73 of 73
G
Hi All, I trying to find a solution also - 3ds MAX 2023.  I have a plane in exercise they turn invisible automatically.  I'm not sure how to solve - any ideas welcome - G
