- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
This happens a lot for me to. Very annoying. I first noticed this in max 2018 but it happens in 2017 also when I checked. To be able to see the textures when this happens i have to change the shading mode to facets instead of default shading.
To fix this I try starting up more max instances until one of them suddenly works. Or close max, delete the enu folder, start max again, open a scene to check if everything is fine which it usually is. Close max again. Then delete the enu folder and use my copied enu folder with all my settings instead and start max again. This works sometimes but not always.
I encounter this several times a week or even per day sometimes.
I never had this kind of problems before. But now om on new hardware and win 10 instead of win 7. Maybe win 10 and max does not work so great?
I have the same problem on both of my computers. They have identical hardware and operating systems though. Soon I will get a new laptop, it will be interesting to see if the same problem occurs on that.
Windows 10 - 64 Gig RAM - Nvidia quadro P5000 with driver 376.33 - Dual Intel Xeon E5 2687W v4 - 512 Gig SSD
EDIT: Posts moved and title updated. -Alfred
