Hello all,
I had a problem with the display of dialogues and the boxes are long because I do not have a graphic card in my laptop, so is there any version that I can run without needing a graphic card? or is there any other solution that may helps?
Not sure if this is still available, but you can try starting Max with the "-h" option from a command prompt. That should bring up a display driver selection box. From here you can choose a different type and see if one works.
C:\Program Files\Autodesk\3ds Max 20xx\3dsmax.exe -h
Can you perhaps share a screenshot of the problem so we can better understand it. Are your resolution settings perhaps not too low?
