3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Problem with display in 3ds max
6 REPLIES 6
yasminefsili003
341 Views, 6 Replies
Hello all,
I had a problem with the display of dialogues and the boxes are long because I do not have a graphic card in my laptop, so is there any version that I can run without needing a graphic card? or is there any other solution that may helps?
Tags (3)
6 REPLIES 6
Morne3D
in reply to: yasminefsili003
Not sure if this is still available, but you can try starting Max with the "-h" option from a command prompt. That should bring up a display driver selection box. From here you can choose a different type and see if one works.
C:\Program Files\Autodesk\3ds Max 20xx\3dsmax.exe -h
yasminefsili003
in reply to: Morne3D
I tried it all but sadly it is still the same :"(
I really need it for my study and I did not find a solution
Morne3D
Can you perhaps share a screenshot of the problem so we can better understand it. Are your resolution settings perhaps not too low?
yasminefsili003
I could not post the picture, it refuse it
Morne3D
stick it on a filesharing site, and share the link to it
yasminefsili003
