3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Please help, UI displays black boxes 3ds Max
3 REPLIES 3
1147 Views, 3 Replies
Your post subject line has been edited by @hagen.delossPlease help
3 REPLIES 3
Daf
First off - does your system meet the minimum requirements to run Max? System requirements for Autodesk 3ds Max 2018
Have searched for answers? Google keyword search
You can try resetting Max Reset Max
Good luck!
3DS Max 2020.3
i7-4790 @4GHz • 32GB • GTX 1080/8GB • Windows 7 Pro
brentscannell
Hi @Anonymous
This might be color theme related. You can try resetting your preferences as @Daf  suggested, but if you're concerned about losing user settings then you can try to restore the default color scheme. Under the "Customize" menu, go to the "Custom UI and defaults switcher" item. In that dialog, on the right hand side, select ame-dark and click "set". You will need to restart 3ds Max before the effects are fully applied.
hagen.deloss
@Anonymous
Any ideas or questions on @Daf  or @brentscannell  suggestions? It would be helpful if you had time to give an update, that way other Community Members can benefit from your process 😄
Please select the Accept as Solution button if a post solves your issue or answers your question.
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
