3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
PFlow for mosaic effects
1 REPLY 1
trinitifx
286 Views, 1 Reply
There is a great plugin for AE called 'Pastiche' that creates mosaics, even animated
https://www.youtube.com/watch?v=8I924WhYrw0
Is something like this possible with PFlow in Max?
I assume you need camera facing particles.
How would the particles take the form of a shape/mesh?
1 REPLY 1
in reply to: trinitifx
Like you said, you would use a combination of 'Position Object' with 'Shape Facing'.
  • Position Object allows you to place particles on objects or subobject-selections.As an alternative you can use Birth Texture to place particles with the help of a texture on an object.
  • A 'Spin' operator  gives you random rotation, but you will have to enable 'Allow Spinning' in Shape Facing operator for this to work.
  • Material Dynamic does the random distribution of materials/maps for the particles. It might also work with RandomizedBitmaps OSL shader, but i didn`t try.
I attached a scene file in 2017 format.
Also you can do interesting effects using DataChannel modifier and the RandomizedBitmap OSL shader.
Technology Administrators
