Alfred,
The error descriptions from the Event Viewer.
Hope this helps somewhat
All the best
Graham
The description for Event ID 3 from source NVWMI cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
NVWMI - Windows Logon User Interface [c:/windows/system32/logonui.exe] was launched and [Windows Logon User Interface] profile was applied
the message resource is present but the message is not found in the string/message table
Fault bucket 129344023940, type 5
Event Name: AppHangB1
Response: Not available
Cab Id: 0
Problem signature:
P1: 3dsmax.exe
P2: 19.51.835.0
P3: 584141b4
P4: 4068
P5: 134217984
P6:
P7:
P8:
P9:
P10:
\\?\C:\Users\Graham_Zeon\AppData\Local\Temp\WERF5F6.tmp.appcompat.txt
These files may be available here:
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppHang_3dsmax.exe_3da8f655dad072a29916fc6419d5551ddb8130a3_847e82e5_1bca1044
Analysis symbol:
Rechecking for solution: 0
Report ID: 446de9eb-e954-11e6-99fa-60a44c21bff9
Report Status: 0
Display driver nvlddmkm stopped responding and has successfully recovered.
The program 3dsmax.exe version 19.51.835.0 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Security and Maintenance control panel.
Process ID: 1c04
Start Time: 01d27d5f77c3949a
Termination Time: 47
Application Path: C:\Program Files\Autodesk\3ds Max 2017\3dsmax.exe
Report Id: 446de9eb-e954-11e6-99fa-60a44c21bff9
Faulting package full name:
Faulting package-relative application ID:
- System
- Provider
[ Name] Application Hang
- EventID 1002
[ Qualifiers] 0
Level 2
Task 101
Keywords 0x80000000000000
- TimeCreated
[ SystemTime] 2017-02-02T14:31:35.671171600Z
EventRecordID 2412
Channel Application
Computer DESKTOP-E0USL1H
Security
- EventData
3dsmax.exe
19.51.835.0
1c04
01d27d5f77c3949a
47
55006E006B006E006F0077006E0000000000
Binary data:
In Words
0000: 006E0055 006E006B 0077006F 0000006E
0010: 0000
In Bytes
0000: 55 00 6E 00 6B 00 6E 00 U.n.k.n.
0008: 6F 00 77 00 6E 00 00 00 o.w.n...
0010: 00 00 ..
