Opening UV Editor Crashes Max 2021
Nick.Pazdan
Message 1 of 57
Nick.Pazdan
Only reference I can find from a similar issues on the forums is a 9-year-old post. Applying an Unwrap UVW modifier to any object in 2021 and trying to open the UV Editor from the subsequent menu results in a "Sorry an error has occurred and the program will now close" message. It happens with existing and new scenes. This behavior is not present on a 2019 install of Max.
I have VRay, Substance, Floor Generator, and Itoo's set of free plugins installed, but otherwise this is a fresh install of Max on a Windows 10 rig. Any ideas on possible solutions? I was doing a test run with 2021 to justify updating our studio to the latest version but UV's are a pretty critical part of the workflow.
Replies (56)
Message 21 of 57
curtis
Observer
Observer
Same issue... please fix- it's really messing with our workflow.
Message 22 of 57
JeanNelson4926
Observer
Observer
I got the same problem flip whats the solution
Message 23 of 57
Hamza_PS
Observer
Observer
I'm facing the same problem,
the application immediately crashes whenever I open the "Unwrap UVW" modifier.
I'm using 3ds Max 2021.1  update. and I've already reported the problem.
I use also vray, Itoo FP, substance, Win 10
Message 24 of 57
logan_foster_adsk
Hey everyone, we have been trying to track this down on our end but haven't had much success thus far. As such if you have any sample scenes for us to try, please upload them as this will help us a lot with tracking down this issue. Thanks.
Message 25 of 57
Hart3D
Guys - the solution was covered a bit earlier in this thread.  You need to change the Custom Defaults UI back from Max.Vray to the Max Default.  I found that scenes that were saved at some point with max.Vray would still crash even though the Default was reinstated.  Any new scenes however would run the UVUnwrap OK.
Message 26 of 57
JonasNoell
from my feeling I don't think it is so difficult to track it down 🙂
1. Customize -> Customs Default Switcher -> Max.vray
2. Restart 3ds Max
3. Create a teapot and add a UVW Modifier
4. Press "Open UV Editor"
5. See Max crash
6. Recreate steps 3-5 with any other possible geometry that you can imagine
Message 27 of 57
logan_foster_adsk
Thanks Jonas. In this case since we are dealing with so many 3rd party tools, scenes will still help the best as they will capture the condition of the scene as they were saved, allowing us to really see what is going on faster/better. So if you're able to quickly post up some .max files it will help us triage it based on what is going on local for your system.
Message 28 of 57
JonasNoell
sure if it helps you. I'm not running any 3rd party plugins apart from V-Ray 5. So I don't think it has anything to do with anything except the combination of V-Ray and 3ds Max 2021.
Greets,
Jonas
Message 29 of 57
 only have vray5 installed.  But the problem comes even if I start a new scene, make a cube, convert it to editable polygon and then try to use the unwrap.
Message 30 of 57
JonasNoell
I can also verify that if I switch back my max defaults (in my case max.legacy), close 3ds Max and reopen it and then open the scene I just posted before it will also crash. But if I create a fresh scene and redo a new teapot then it doesn't.
I think it has to do with the materials that are populated in the material editor if you start a scene from scratch. So if I start a scene with max.vray defaults then it would be populated with V-Ray materials, while if I start with max.legacy it would be populated with Standard materials. These materials would also be saved in the scene that's why even switching back to the max.legacy defaults will crash the scene because the materials in the editor are the ones from the max.vray.
I hope that might help you to track this 🙂
Message 31 of 57
logan_foster_adsk
Thank you for the files and information, this will help our developer see what is going on
Message 32 of 57
jon.bell
Gary,
Do you still have a copy of your "bad" ENU folder settings? If so, I would very much like to get zipped versions of both the "bad" and "good" ENU folders so I can forward them to our developers.
Please let me know, and I'll send you a private OneDrive link where you can upload them. Thanks!
Jon A. Bell
Senior Technical Support Specialist, 3ds Max
Message 33 of 57
jon.bell
Hi Habitat,
Please see your private messages. We've logged this as a 3ds Max defect, and our developers and the V-Ray folks are looking into this.
I am curious about something: if resetting your user preferences back to default fixes this issue (temporarily), could you please let us know? If so, I'd like to get zipped copies of both your "bad" ENU folder and your new one so our developers could compare them. Thanks!
Jon A. Bell
Message 34 of 57
Hi, thanks for your post, i had tracked the string in config file.
hope it wll be heplfull.
in file:
C:\Users\...\AppData\Local\Autodesk\3dsMax\2021 - 64bit\ENU\en-US\defaults\MAX.vray\CurrentDefaults.ini
find:
[100 C80 0]
; V-Ray Material
materialType=0x37bf3f2f 0x7034695c
change materialType:
from
to
materialType=0x3d6b1cec 0xdeadc001
(taken from default max config.ini)
works for me in 3ds max 2021.1 with Vray 5.00.04
Message 35 of 57
jon.bell
Hi Johny,
Thanks for the update! I've posted your comments in the logged defect we have for this issue, so we'll see what our developers say. 🙂
Jon A. Bell
Message 36 of 57
Glad to help. I hope the developers will fix this problem
Message 37 of 57
jon.bell
Hi folks,
I'm checking with the 3ds Max dev team to see what our discussions have been with Chaos Group and iToo Tools on this, and what the status is of fixing these UV Unwrap issues. I'll report back as soon as I have some updates for you. Thanks!
Jon A. Bell
Message 38 of 57
mtausif
Thanks MAn! This works for me to. You are a genius. 😊
Message 39 of 57
keith112
This worked for me too. Vray version 3.7
Message 40 of 57
Hello, I am experiencing the same crashes as everyone else EXCEPT I do not have VRay installed.  As mentioned earlier, I renamed my ENU folder to ENU_old.  Max generated a new one and Max no longer crashes after applying UnwrapUVW.  This issue is not limited to VRay users.
