The 3ds Max dlls seem to vanish one fine day, upon closer inspection I found that there was a windows update. Now after that I have repaired , reinstalled and uninstalled and performed a clean reinstall of 3ds Max 2017 but it still does not seem to work.
This is the error i seem to be getting.
Thanks in advance for helping me out.
Solved by Alfred.DeFlaminis. Go to Solution.
So after some research , I came across this solution.
http://forums.autodesk.com/t5/installation-hardware-os/mentalray-dll-not-loading-max17/td-p/6282811
but upon installation it doesn't seem to work
when selected , ( the blank areas assuming they've got the rendering modes) 3ds max crashes
Hello @Anonymous and @Anonymous,
This thread is before my time but it never got an answer so I wanted to answer here. Mental Ray seems to be not installed or has an installation issue, please try to reinstall it. I have included the installers in my attachment. You'll want to run the installer as an administrator if you have any issues. Thank you! Please let me know if you have problems.
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
Hello @Anonymous,
For the first time I can remember, the list of install options was scrollable in the 2017 setup and a lot of people have missed the Mental Ray installers. What is strange is for me they are enabled by default but I gather that is not the case for everyone. I'm glad it's working now and thanks for posting the link, kudos given!
Admin is required for some people, but not all it seems. I think this has to do with various anti-virus software and running as admin seems to create exceptions for the AV programs.
Best Regards,
