3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Keyboard Inputs freeze 3DS MAX
18 REPLIES 18
Message 1 of 19
7860 Views, 18 Replies
Please help! I am using max2020 (Also tried with other versions). If only using mouse as input, it will be fine for a while at least until I am trying to using keyboard short cuts, for instance, shift-Q as render, and sometimes, alt-w/ alt-mmb will freeze the apps. For example, after launching 3dsmax, and pressing shift-q, the app will freeze right away, there will be no more response no matter what. Sometimes it could be mitigated by killing the chromium host exe.
I have tried below......formatting the computer, installing the latest drivers/ bios/ windows. No plugin installed. Run as admin. Disabled the autodesk desktop app services.msc..
Spec:
window 10
i7
rtx2080ti
Spec:
window 10
i7
rtx2080ti
18 REPLIES 18
Message 2 of 19
DanielCantin
DanielCantin
Hi @Anonymous,
I suspect it is an issue with the latest Windows update (Ver 2004, Build 19041) that is affecting none English input method language. The workaround is to check "ON" use old version Microsoft Pinyin input method in windows setting.
Thanks for reaching out with your issue and please let us know if that solve your issue or not
-Daniel
Daniel Cantin
QA Manager, 3ds Max, Maya
Entertainment Creation Products, DCP
Hi @Anonymous,
-Daniel
Daniel Cantin
Message 3 of 19
in reply to: DanielCantin
omg!!!! you are my god, holy X! I LOVE YOU, seems fine! It worked! thank you one thousand!
Message 4 of 19
I can confirm the same on a Japanese OS. Been bugging me for a couple of weeks now. Thanks for this solution.
Message 5 of 19
EricLiu4Ever
EricLiu4Ever
Observer
Observer
2 days earlier, I installed a third party input method and removed the MS Pinyin keyboard, and the problem is gone.
Max (2016, 2019, 2020, and 2021) usually gets freeze when rendering complete and saving the result on my windows 10 with the most recent windows updates. Now the problem is gone.
Message 6 of 19
After searching the solution for weeks, I finally got solved. Thanks very much!
Message 7 of 19
mark_aldred
mark_aldred
@Anonymous
Which setting did you change on the Japanese OS?
@Anonymous
Message 8 of 19
mark_aldred
mark_aldred
Never mind, I found it .. set to old version of IME deep into the language settings.
Wish I'd found this thread earlier. Would have saved me about ten hours.
Message 9 of 19
in reply to: mark_aldred
good for u!
good for u!
Message 10 of 19
in_human
in_human
Getting same problem with RUssian/UkrAinian?
Any solutions?
Any solutions?
Message 11 of 19
mark_aldred
in reply to: in_human
mark_aldred
Have you been into your language settings? Is there something that allows you to set input to "old method" or something like that?
Message 12 of 19
in_human
in_human
No, there's no "old IME" setting for russian and ukrainian languages.
Freeze doesn't happen when I use standard win+space hotkey, it only happens if I try to set particular layout with custom hotkey.
I tried setting custom hotkeys through standard windows setting or writing script for autohotkey, result is the same - 3ds MAX freezes when I try to set non-English layout, even if I'm using another program at the moment.
Very frustrating.
Very frustrating.
Message 13 of 19
Apologies - I haven't been clear on the problem and the solution - I work within a Japanese OS environment and use English as well as an input language and also as the UI display language. The problem for this particular machine and 3DSMAX, is that every time I rename an object or hit a shortcut key - max freezes while typing out. I followed the solution for Ichdennis as suggested by Daniel and the problem went away.  Go to settings - search for Microsoft IME>General> And turn that compatibility with OLD IME "ON". I am not sure if this is the same solution for those using Windows in a different OS other than Japanese.
Message 14 of 19
Ijustcant
Ijustcant
I believe this might be the solution: http://forum.navi.gg/dota2_nastroyki_tehpomosch_i_utility/zavisaet_pri_smene_yazyka/ but I don't know how to perform this on Windows 10
Also, this might something to do with this: https://lopit.ru/word-visnet-switcher/
But I can't perform it either...
Message 15 of 19
JeromeBoulbes
JeromeBoulbes
I want to confirm that this solved the issue for me, on max 2021, Japanese keyboard, english OS.
The setting was renamed to "use previous version of Microsoft IME" but is  still in the Setting/japanese IME settings/general
Strangely, this issue occured to me only after I had rendered with Arnold or used the Arnold Active Shading.
Thanks everyone
Thanks everyone
Message 16 of 19
can you give me the link? thanks you so much...
Message 17 of 19
Works great for me! Saved my day, thank you Daniel!
Message 18 of 19
laicarmenn97
laicarmenn97
Community Visitor
Community Visitor
hi may I knw where do u find this window ?
Message 19 of 19
pinky0371
pinky0371
Community Visitor
Community Visitor
i use F10 to render is ok .
but while use "Shift" + "Q"Render finish will freeze .
when turn OLD IME "ON" . work well now . many thanks
