3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
How to remove instance from objects?
9 REPLIES 9
Message 1 of 10
15625 Views, 9 Replies
I've imported my Revit file in 3ds and when I move my selected windows and walls to another level, the unselected windows are moving too. I guess this is an "instance" thing. Is there any was to remove this and make the objects standalone in the scene, so I can move only the selected ones?
9 REPLIES 9
Message 2 of 10
Take a "Snapshot" of the objects you don't want to move...make sure you pick COPY...delete the originals...they will stay selected so after completing the Snapshot just hit the delete key.
Message 3 of 10
Yea!! Thanks a lot man. This works like a charm. Cheers
Message 4 of 10
Steve_Curley
Select them, right-click in the Stack (on the bold line) > Make Unique ?
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 5 of 10
in reply to: Steve_Curley
OK, OK, you got the better answer AGAIN...but you were 1 1/2 hrs late...;-)
Message 6 of 10
Steve_Curley
Blame Skyrim. And shopping... 😄
Max 2016 (SP1/EXT1)
Message 7 of 10
PiXeL_MoNKeY
Instancing won't cause separate geometric objects to move together. That would be grouping or hierarchy that causes this effect. Could you post a video of exactly what is happening?
-Eric
Message 8 of 10
Steve_Curley
in reply to: PiXeL_MoNKeY
Unless he means moving them between Layers. Does Revit group and/or link objects which are instances? I've never used it so I don't know.
Max 2016 (SP1/EXT1)
Message 9 of 10
Don't worry...whatever he was trying to explain, we fixed it...never mind the proper terminology that you cling to.
Message 10 of 10
MaKarf
Thanks very much for the solution. I also had the same issue just now and your answer saved me from the mess
