3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
How to remove instance from objects?
9 REPLIES 9
Message 1 of 10
15869 Views, 9 Replies
I've imported my Revit file in 3ds and when I move my selected windows and walls to another level, the unselected windows are moving too. I guess this is an "instance" thing. Is there any was to remove this and make the objects standalone in the scene, so I can move only the selected ones?
9 REPLIES 9
Message 2 of 10
Take a "Snapshot" of the objects you don't want to move...make sure you pick COPY...delete the originals...they will stay selected so after completing the Snapshot just hit the delete key.
Message 3 of 10
Yea!! Thanks a lot man. This works like a charm. Cheers
Message 4 of 10
Steve_Curley
Steve_Curley
Select them, right-click in the Stack (on the bold line) > Make Unique ?
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Max 2016 (SP1/EXT1)
Message 5 of 10
in reply to: Steve_Curley
OK, OK, you got the better answer AGAIN...but you were 1 1/2 hrs late...;-)
Message 6 of 10
Steve_Curley
Steve_Curley
Blame Skyrim. And shopping... 😄
Max 2016 (SP1/EXT1)
Max 2016 (SP1/EXT1)
Message 7 of 10
PiXeL_MoNKeY
PiXeL_MoNKeY
Instancing won't cause separate geometric objects to move together. That would be grouping or hierarchy that causes this effect. Could you post a video of exactly what is happening?
-Eric
-Eric
Message 8 of 10
Steve_Curley
in reply to: PiXeL_MoNKeY
Steve_Curley
Unless he means moving them between Layers. Does Revit group and/or link objects which are instances? I've never used it so I don't know.
Max 2016 (SP1/EXT1)
Max 2016 (SP1/EXT1)
Message 9 of 10
Don't worry...whatever he was trying to explain, we fixed it...never mind the proper terminology that you cling to.
Message 10 of 10
MaKarf
MaKarf
Observer
Observer
Thanks very much for the solution. I also had the same issue just now and your answer saved me from the mess
