Solved by Alfred.DeFlaminis. Go to Solution.
Solved by timd1971. Go to Solution.
Solved by Steve_Curley. Go to Solution.
Chris Medeck
Hello @Anonymous,
In 2018 that is located in Customize->Customize User Interface->Mouse menu.
You can also disable Adaptive Navigation which may help.
Go to C: \Users\[YourUserName]\AppData\Local\Autodesk\3dsMax\2015 - 64bit\ENU\3dsmax.ini
and add "AdaptiveNavigation=0" in the [Performance] section.
[Performance]
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
I solved the problem by switching to another mouse and then back to mine wireless.
But with time it again appears
Also after about 10-20 minutes Wheel Zoom Increment goes back to 10mm... ( and i have to switch it back to minimum every 10-20 min of workflow)
I guess it is not supposed to be like that....
Hello @Anonymous, would you mind listing the make/model of your mouse for me please? I'll make a note of it. Thanks!
Best Regards,
I found out that if you it the "A" key it will auto adjust the size of the scene to the scroll sensitivity. Very annoying place to put that key.
I fixed mine by shrinking my whole scene hitting, "a" and then re-grew it. and changed that annoying hotkey.
