3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
How can i remove all shadow from the view port in 3ds max 22 or 23!!
2 REPLIES 2
farazpy
366 Views, 2 Replies
Hi friends
when i worked in 3ds max 2020 before! i could removed all shadow from every view angle in view port and any objects are sold and without any shadow but now i can't do that in 3ds max 2022
or 23 Especially when I want to look down from the top max view port !!
To facilitate the conversation
in view port performance:
illuminate : default lights
default lights :  2 default lights
quality : point light /hard shadow
and other options in down there are turned off
2 REPLIES 2
RobH2
in reply to: farazpy
One thing that might help you is that you can change the viewport display from "Default Shading" to "Flat Color". That removes all lighting shading and might help you see what you are trying to. I use it a lot.
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
farazpy
Thanks for suggesting but i knew that and this is not what i want!
can i change the shadow contrast or is there any option that i can adjusting ((darkness/brightness)) the shadow ?
