Hi friends
when i worked in 3ds max 2020 before! i could removed all shadow from every view angle in view port and any objects are sold and without any shadow but now i can't do that in 3ds max 2022
or 23 Especially when I want to look down from the top max view port !!
To facilitate the conversation
in view port performance:
illuminate : default lights
default lights : 2 default lights
quality : point light /hard shadow
and other options in down there are turned off
Solved by RobH2. Go to Solution.
One thing that might help you is that you can change the viewport display from "Default Shading" to "Flat Color". That removes all lighting shading and might help you see what you are trying to. I use it a lot.
Rob Holmes
------------------------------------------------------------------------------------------------------------------------------------------Thanks for suggesting but i knew that and this is not what i want!
can i change the shadow contrast or is there any option that i can adjusting ((darkness/brightness)) the shadow ?
