Help with Physx plugin installation
Message 1 of 9
Hi all, I downloaded the Physx plugin from nvidia but cant seem to get it up and running, as soon as i start up max it says, "Error 126, pxplugin.dlm failed to initialise", i looked in the plugin folder and the file is there so why is it failing to start ??, i downloaded the latest drivers from nvidia and the physx sdk and installed them, i am using a gforce 6200 graphics card and 3ds max 2009, all the components of the plugin seem to be their in the utilites panel but when it just wont let me do anything with it. Any help apreciated, thank.
Replies (8)
Message 2 of 9
hi i too had the same problem later i figured out that Physx supports only Geforce 8 series cards(i own a 7300) didnt work for me too
Message 3 of 9
thanks, looks like it time to upgrade my grapgics card then !.
Message 4 of 9
Good day to everyone! I have the same problem (error code 126 with pxplugin.dlm), but GPU is 8600 GT and have сompatibility with PhysX.. Why this driver is not working? In advance thanks, and sorry for my illiterate english.
ASUS EN8600GT
3DS Max 9
Message 5 of 9
Steve_Curley
This a Max 2009 forum. If you have Max 9 you should post in the "Max through 2008" forum, or the Plugins forum. Does that plugin say it will work with Max 9?
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 6 of 9
I apologise, has found this post through search. Yes, installer itself suggests to choose the version (9,2008,2009) and itself finds a path of 3D Max. The problem has solved, it was necessary to install the basic PhysX (PhysX_9.09.0814_SystemSoftware.exe).
Message 7 of 9
Steve_Curley
Useful to know that it's not just a case of installing the plugin. Thanks for posting the solution.
Max 2016 (SP1/EXT1)
Message 8 of 9
Hey thanks COoo1d for the info on the exe file to install this plugin, i thought i would gice it one last try and i installed the file and it is working using my Geforce 6200 graphics card, seems much better than reactor as well, tried out the example tutorial in the user help files and there was no colision gap at all between the two objects, Looks like no need to upgrade my graphics card at all which is good news as my motherboard dont support PCI-E Cards.
Message 9 of 9
Was glad to help :)
