Explode elements into seperate objects
luke.penry
Message 1 of 11
luke.penry
I have always wondered why this doesn't exsist and only realised now what a limitation it is.
Unless, does anyone know a way in 3ds max to detach all elements in an object into seperate objects? I really don't want to individually seperate 100 elements.
Replies (10)
Message 2 of 11
10DSpace
Hi @luke.penry
There is a handy free script called "Object Detacher" in the collection of Soulburn scripts here:
http://www.neilblevins.com/art_assets/scripts/soulburnscripts_for_3dsmax.htm
  The whole collection of scripts is very useful and I use many of them regularly in my work.
However, only supported through Max 2022.
Message 3 of 11
domo.spaji
Edit Mesh...
Explode - To Objects
Set angle to max (180)
Message 4 of 11
luke.penry
This appears to explode every face into its own object rather than the elements
Message 5 of 11
luke.penry
Thank you, yes I had found this, but like you say as it's been discontinued, its time is limited.
Seriously we need a simple function to be brought into 3ds to do this. As the software is evolving with plugins like Tyflow and vairous other scatter and particle systems, the need to seperate objects is needed more than ever.
Message 6 of 11
darawork
Just adding my suggestions that I use:
https://www.scriptspot.com/3ds-max/scripts/strtools (The sAttach routine, in the Modifier section)
https://www.scriptspot.com/3ds-max/scripts/detach-by-material-id (For when you want to detach by material ID)
Both work pretty well, depending on the type of seperations you want to perform.
Darawork
AutoDesk User
Windows 11, 3DS Max 2026, Revit 2026, AutoCad 2026, Dell Precision 7875 nVidia - Quadro RTX4000 ATA - AMD Ryzen Threadripper PRO 7965WX 24-Cores - 128GB RAM
Message 7 of 11
domo.spaji
In that case I wouldn't suggest you that solution.
I have read and understood your question, please read my answer, it is not long.
Message 8 of 11
10DSpace
@luke.penry
Here is a script that detaches by element or Mat ID and is compatible with Max 2023 and earlier versions:
http://www.scriptspot.com/3ds-max/scripts/detachplus
Has a few other nice features.
Message 9 of 11
MJH_MJH
Thanks! it worked!
Message 10 of 11
akcharly
Awesome script! Thank you very much!
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" повідомленню! | Do you find the posts helpful? "LIKE" these posts!
На ваше запитання відповіли? Натисніть кнопку 'ПРИЙНЯТИ РІШЕННЯ' | Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Андрiй Кривуля | Andrew Krivulya | 3D Grooming Artist - Facebook | Instagram | Twitter | LinkedIN | Youtube | Artstation
Message 11 of 11
Victorgan
@domo.spaji wrote:
Edit Mesh...
This actually works, no script needed. Just make sure your settings match this and you'll get exploded sub-objects, not faces.
